Device string and value not updated
  • Device string and value not updated
    Hi Philippe,
    I've bought your plugin for my HS3 server (in test for the moment).
    I've connected an APC Back-UPS CS650 with usb cable and an APC Smart-UPS 2200 remotely
    In status page, I can see almost all fields, excepted Nominal Power, Input Voltage, Low & High Line Voltage, Low & High Load, Low & High Battery Charge
    But in device manager, only the following are filed :
    Name
    Start Time
    Last Updated
    Status flag
    Status
    Time Left
    Last on Battery
    Lost off Battery
    Total Time on Battery
    Number of Transfers
    Do you have any idea ?
    Thanks in advance.
    Yves
    If you don't see the values in the plugin status page most likely the UPS is not sending these via APCUPSD or the plugin could not decode them. Try the following:
    a) in the apcupsd status (from the icon in the toolbar) do you these values?
    b) enable debut + verbose debug in the plugin. The log file should contain what the plugin receives and can decode. If you post the log I can have have a look at it as well.
    Bonne journee.
      Hi Philippe,
      In the apcupsd status, I can see all informations. On local and on remote PC.
      Here is the verbose log (the UPS1 is the remote one, UPS2 is the local) :
      sept.-23 13:38:02 APCUPSD Debug --------------- refreshTimer END -----------------
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 237, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 236, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 235, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 234, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 233, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 232, Value: 1
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 231, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 230, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 229, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 221, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 222, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 228, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 227, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 226, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 225, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 224, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 223, Value: 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 218, Value: 1411479481
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 217, Value: 1411433570
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 219, Value: 1
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 220, Value: 1
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 216, Value: 2
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Update devices for UPS2
      sept.-23 13:38:02 APCUPSD (UPS2) Debug QueryStatusAndEvents - Query status and events for UPS2 done
      sept.-23 13:38:02 APCUPSD (UPS2) Debug QueryStatusAndEvents - Got status
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entered tcpClient_onDisconnect() UPS2
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (36): END APC : 2014-09-23 13:38:01 +0100
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (29): FIRMWARE : 817.v4.I USB FW:v4
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): NOMPOWER : 400 Watts
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): NOMBATTV : 12.0 Volts
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): NOMINV : 230 Volts
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): NOMOUTV : 230 Volts
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): BATTDATE : 2012-05-02
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): SERIALNO : 3B0622X58167
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): MANDATE : 2006-05-28
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): STATFLAG : 0x05000008
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (15): STESTI : None
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (13): SELFTEST : NO
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (14): XOFFBATT : N/A
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): CUMONBATT: 0 Seconds
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): TONBATT : 0 Seconds
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (12): NUMXFERS : 0
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (27): LASTXFER : Low line voltage
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (18): LINEFREQ : 50.0 Hz
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): BATTV : 13.6 Volts
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (19): ALARMDEL : No alarm
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (17): ITEMP : 29.2 C
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): RETPCT : 0.0 Percent
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): HITRANS : 256.0 Volts
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): LOTRANS : 180.0 Volts
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): DSHUTD : 0 Seconds
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): DWAKE : 0 Seconds
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (17): SENSE : Medium
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): OUTPUTV : 230.0 Volts
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): MAXTIME : 0 Seconds
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): MINTIMEL : 3 Minutes
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): MBATTCHG : 5 Percent
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): TIMELEFT : 32.5 Minutes
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (24): BCHARGE : 100.0 Percent
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): LOADPCT : 10.0 Percent
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): LINEV : 246.0 Volts
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (17): STATUS : ONLINE
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (26): MODEL : Back-UPS CS 650
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (36): STARTTIME: 2014-09-23 00:52:50 +0100
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): UPSMODE : Stand Alone
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (25): DRIVER : USB UPS Driver
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): CABLE : USB Cable
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (19): UPSNAME : BATIMENT
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (40): VERSION : 3.14.12 (29 March 2014) Win32
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (16): HOSTNAME : DOMO2
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (36): DATE : 2014-09-23 13:38:01 +0100
      sept.-23 13:38:02 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): APC : 001,045,1037
      sept.-23 13:38:01 APCUPSD (UPS2) Debug QueryStatusAndEvents - reading status
      sept.-23 13:38:01 APCUPSD (UPS2) Debug QueryStatusAndEvents - Query status for UPS2 from network
      sept.-23 13:38:01 APCUPSD (UPS2) Debug QueryStatusAndEvents - Connected and query status
      sept.-23 13:38:01 APCUPSD (UPS2) Debug Entering QueryStatusAndEvents for UPS2
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 166, Value: 86
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 165, Value: 163
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 164, Value: 0
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 163, Value: 1411434058
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 162, Value: 1411434057
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 161, Value: 1
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 160, Value: 0
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 159, Value: 0
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 158, Value: 0
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 150, Value: 0
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 151, Value: 0
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 157, Value: 0
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 156, Value: 0
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 155, Value: 0
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 154, Value: 0
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 153, Value: 0
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 152, Value: 0
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 147, Value: 1411479492
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 146, Value: 1406396492
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 148, Value: 1
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 149, Value: 1
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 145, Value: 2
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Update devices for UPS1
      sept.-23 13:38:01 APCUPSD (UPS1) Debug QueryStatusAndEvents - Query status and events for UPS1 done
      sept.-23 13:38:01 APCUPSD (UPS1) Debug QueryStatusAndEvents - Got status
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entered tcpClient_onDisconnect() UPS1
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): END APC : 2014-09-23 13:38:16 +0100
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (18): FIRMWARE : 80.14.I
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (12): EXTBATTS : 0
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): NOMBATTV : 48.0 Volts
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): NOMOUTV : 225 Volts
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (19): BATTDATE : 06/28/13
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (23): SERIALNO : YS0321210433
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (19): MANDATE : 05/20/03
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): REG3 : 0x00
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): REG2 : 0x00
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): REG1 : 0x00
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): DIPSW : 0x00
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): STATFLAG : 0x05000008
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (14): STESTI : 336
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (13): SELFTEST : NO
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): LASTSTEST: 2014-09-20 17:39:50 +0100
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): XOFFBATT : 2014-09-23 01:00:58 +0100
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): CUMONBATT: 163 Seconds
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): TONBATT : 0 Seconds
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): XONBATT : 2014-09-23 01:00:57 +0100
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (13): NUMXFERS : 86
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (38): LASTXFER : Line voltage notch or spike
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (18): LINEFREQ : 50.0 Hz
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): BATTV : 55.0 Volts
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): ALARMDEL : Low Battery
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (17): ITEMP : 32.8 C
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): RETPCT : 0.0 Percent
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): HITRANS : 253.0 Volts
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): LOTRANS : 196.0 Volts
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): DLOWBATT : 2 Minutes
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): DSHUTD : 180 Seconds
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): DWAKE : 60 Seconds
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): SENSE : High
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): OUTPUTV : 247.0 Volts
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): MINLINEV : 236.6 Volts
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): MAXLINEV : 249.6 Volts
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): MAXTIME : 0 Seconds
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): MINTIMEL : 3 Minutes
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): MBATTCHG : 5 Percent
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (24): TIMELEFT : 139.0 Minutes
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (24): BCHARGE : 100.0 Percent
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (23): LOADPCT : 12.4 Percent
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): LINEV : 247.0 Volts
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (17): STATUS : ONLINE
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (25): MODEL : SMART-UPS 2200
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): STARTTIME: 2014-07-26 17:41:32 +0100
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): UPSMODE : Stand Alone
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (30): DRIVER : APC Smart UPS (any)
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (29): CABLE : Custom Cable Smart
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (18): UPSNAME : APC2200
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (40): VERSION : 3.14.12 (29 March 2014) Win32
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (19): HOSTNAME : domoware
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): DATE : 2014-09-23 13:38:12 +0100
      sept.-23 13:38:01 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (23): APC : 001,053,1256
      sept.-23 13:38:00 APCUPSD (UPS1) Debug QueryStatusAndEvents - reading status
      sept.-23 13:38:00 APCUPSD (UPS1) Debug QueryStatusAndEvents - Query status for UPS1 from network
      sept.-23 13:38:00 APCUPSD (UPS1) Debug QueryStatusAndEvents - Connected and query status
      sept.-23 13:38:00 APCUPSD (UPS1) Debug Entering QueryStatusAndEvents for UPS1
      sept.-23 13:38:00 APCUPSD Debug Entered refreshTimer_Elapsed()
      sept.-23 13:38:00 APCUPSD Debug --------------- refreshTimer START -----------------
      sept.-23 13:37:22 APCUPSD Debug PostBackProc - Form data name: id Value: verbosedebug
      sept.-23 13:37:22 APCUPSD Debug Entered postBackProc() apcupsd_config. page: apcupsd_config data: erbosedebug=checked&id=verbosedebug user: YC userRights: 6
      sept.-23 13:37:22 APCUPSD Debug Entered PostBackProc(). Page: apcupsd_config data: verbosedebug=checked&id=verbosedebug User: YC userRights: 6
      Hope it'll help.
      Thanks in advance.
        Thank you for posting the log; based on this somehow the plugin cannot parse / extract the value. I will have to look at it this weekend, but my guess is that it is related to some locale settings (. versus ,). Vous etes en France avec une configuration utilisant le comma pour les decimales?
          You're right, I'm in France and run a Windows 7 Pro French.
          I'm using comma by default.
          It's probably the same problem on the HS2 server which is Windows XP Pro SP3 French and can't also update the values.
          Otherwise this plugin seems really perfect.
          Thanks for your help.
            Thanks. I look into it over the weekend. Per the log you posted apcupsd does not use the local and uses a dot instead of a comma and believe that must be the issue.
              I made some changes to see if that will resolve (or work around) the issue. Can you try the attached plugin version as a test?
              Just copy it to the HomeSeer installation folder to overwrite the existing. Merci.
              I did not have enough time to check if apcupsd can be reconfigured to use your French locale for numbers (and therefore be compatible with the numeric conversion which uses your locale).
                Thanks for this, but I doesn't seems to be solved ; I think you'll have to spend more week-ends . Sorry for French locale for numbers...
                sept.-29 05:05:56 APCUPSD Debug --------------- refreshTimer END -----------------
                sept.-29 05:05:56 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 237, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 236, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 235, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 234, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 233, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 232, Value: 1
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 231, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 230, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 229, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 221, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 222, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 228, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 227, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 226, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 225, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 224, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 223, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 218, Value: 1411967111
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 217, Value: 1411915084
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 219, Value: 1
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 220, Value: 1
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered SetDeviceValue(). Setting Device Ref: 216, Value: 2
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Update devices for UPS2
                sept.-29 05:05:55 APCUPSD (UPS2) Debug QueryStatusAndEvents - Query status and events for UPS2 done
                sept.-29 05:05:55 APCUPSD (UPS2) Debug QueryStatusAndEvents - Got status
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entered tcpClient_onDisconnect() UPS2
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (36): END APC : 2014-09-29 05:05:55 +0100
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (29): FIRMWARE : 817.v4.I USB FW:v4
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): NOMPOWER : 400 Watts
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): NOMBATTV : 12.0 Volts
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): NOMINV : 230 Volts
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): NOMOUTV : 230 Volts
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): BATTDATE : 2012-05-02
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): SERIALNO : 3B0622X58167
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): MANDATE : 2006-05-28
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): STATFLAG : 0x05000008
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (15): STESTI : None
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (13): SELFTEST : NO
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (14): XOFFBATT : N/A
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): CUMONBATT: 0 Seconds
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): TONBATT : 0 Seconds
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (12): NUMXFERS : 0
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (27): LASTXFER : Low line voltage
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (18): LINEFREQ : 50.0 Hz
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (21): BATTV : 13.6 Volts
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (19): ALARMDEL : No alarm
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (17): ITEMP : 29.2 C
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): RETPCT : 0.0 Percent
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): HITRANS : 256.0 Volts
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): LOTRANS : 180.0 Volts
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): DSHUTD : 0 Seconds
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): DWAKE : 0 Seconds
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (17): SENSE : Medium
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): OUTPUTV : 230.0 Volts
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): MAXTIME : 0 Seconds
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): MINTIMEL : 3 Minutes
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): MBATTCHG : 5 Percent
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): TIMELEFT : 26.2 Minutes
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (24): BCHARGE : 100.0 Percent
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): LOADPCT : 17.0 Percent
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): LINEV : 240.0 Volts
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (17): STATUS : ONLINE
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (26): MODEL : Back-UPS CS 650
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (36): STARTTIME: 2014-09-28 14:38:04 +0100
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (22): UPSMODE : Stand Alone
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (25): DRIVER : USB UPS Driver
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (20): CABLE : USB Cable
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (19): UPSNAME : BATIMENT
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (40): VERSION : 3.14.12 (29 March 2014) Win32
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (16): HOSTNAME : DOMO2
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (36): DATE : 2014-09-29 05:05:11 +0100
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering ParseUPSStatusOrEvent for UPS2 and line (23): APC : 001,045,1037
                sept.-29 05:05:55 APCUPSD (UPS2) Debug QueryStatusAndEvents - reading status
                sept.-29 05:05:55 APCUPSD (UPS2) Debug QueryStatusAndEvents - Query status for UPS2 from network
                sept.-29 05:05:55 APCUPSD (UPS2) Debug QueryStatusAndEvents - Connected and query status
                sept.-29 05:05:55 APCUPSD (UPS2) Debug Entering QueryStatusAndEvents for UPS2
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 166, Value: 92
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 165, Value: 174
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 164, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 163, Value: 1411866080
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 162, Value: 1411866078
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 161, Value: 1
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 160, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 159, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 158, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 150, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 151, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 157, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 156, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 155, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 154, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 153, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 152, Value: 0
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 147, Value: 1411967162
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 146, Value: 1406396492
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 148, Value: 1
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 149, Value: 1
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered SetDeviceValue(). Setting Device Ref: 145, Value: 2
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Update devices for UPS1
                sept.-29 05:05:55 APCUPSD (UPS1) Debug QueryStatusAndEvents - Query status and events for UPS1 done
                sept.-29 05:05:55 APCUPSD (UPS1) Debug QueryStatusAndEvents - Got status
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entered tcpClient_onDisconnect() UPS1
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): END APC : 2014-09-29 05:06:06 +0100
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (18): FIRMWARE : 80.14.I
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (12): EXTBATTS : 0
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): NOMBATTV : 48.0 Volts
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): NOMOUTV : 225 Volts
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (19): BATTDATE : 06/28/13
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (23): SERIALNO : YS0321210433
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (19): MANDATE : 05/20/03
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): REG3 : 0x00
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): REG2 : 0x00
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): REG1 : 0x00
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): DIPSW : 0x00
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): STATFLAG : 0x05000008
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (14): STESTI : 336
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (13): SELFTEST : NO
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): LASTSTEST: 2014-09-20 17:39:50 +0100
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): XOFFBATT : 2014-09-28 01:01:20 +0100
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): CUMONBATT: 174 Seconds
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): TONBATT : 0 Seconds
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): XONBATT : 2014-09-28 01:01:18 +0100
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (13): NUMXFERS : 92
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (38): LASTXFER : Line voltage notch or spike
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (18): LINEFREQ : 50.0 Hz
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): BATTV : 55.0 Volts
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): ALARMDEL : Low Battery
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (17): ITEMP : 33.7 C
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): RETPCT : 0.0 Percent
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): HITRANS : 253.0 Volts
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): LOTRANS : 196.0 Volts
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): DLOWBATT : 2 Minutes
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): DSHUTD : 180 Seconds
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (21): DWAKE : 60 Seconds
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (15): SENSE : High
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): OUTPUTV : 241.8 Volts
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): MINLINEV : 240.5 Volts
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): MAXLINEV : 243.1 Volts
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): MAXTIME : 0 Seconds
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): MINTIMEL : 3 Minutes
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (20): MBATTCHG : 5 Percent
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (24): TIMELEFT : 123.0 Minutes
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (24): BCHARGE : 100.0 Percent
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (23): LOADPCT : 14.5 Percent
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): LINEV : 241.8 Volts
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (17): STATUS : ONLINE
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (25): MODEL : SMART-UPS 2200
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): STARTTIME: 2014-07-26 17:41:32 +0100
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (22): UPSMODE : Stand Alone
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (30): DRIVER : APC Smart UPS (any)
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (29): CABLE : Custom Cable Smart
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (18): UPSNAME : APC2200
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (40): VERSION : 3.14.12 (29 March 2014) Win32
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (19): HOSTNAME : domoware
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (36): DATE : 2014-09-29 05:06:02 +0100
                sept.-29 05:05:55 APCUPSD (UPS1) Debug Entering ParseUPSStatusOrEvent for UPS1 and line (23): APC : 001,053,1256
                sept.-29 05:05:55 APCUPSD (UPS1) Debug QueryStatusAndEvents - reading status
                sept.-29 05:05:55 APCUPSD (UPS1) Debug QueryStatusAndEvents - Query status for UPS1 from network
                sept.-29 05:05:55 APCUPSD (UPS1) Debug QueryStatusAndEvents - Connected and query status
                sept.-29 05:05:54 APCUPSD (UPS1) Debug QueryStatusAndEvents - Query status for UPS1 from network
                sept.-29 05:05:54 APCUPSD (UPS1) Debug Entering QueryStatusAndEvents for UPS1
                sept.-29 05:05:54 APCUPSD Debug Entered refreshTimer_Elapsed()
                sept.-29 05:05:54 APCUPSD Debug --------------- refreshTimer START -----------------
                  Thanks and yes will have to spend more time looking into this. The issue per the log entries is that apcupsd does not use the locale; at least I think.
                    FYI, I have not forgotten about this tough only had very limited time since my last update.
                      Thanks Philippe, I'll still wait... a few hours
                        Hi Philippe,
                        You're right : i've tried switching local settings from FR to US (dot and not coma) and it works fine. All fields are filled. So this is the issue.
                        I can let it work a moment for testing, but you're next update will be welcome.
                        Thanks in advance.
                          I played with it a bit more over the weekend but not complete yet. The issue is that apcupsd sends the numerical as us local (i.e. Using a dot for the decimal separator) while the local on your PC is a comma as the decimal separator. In the plugin version in the post I forced the conversion for APCSUPSD values to use the us local even if the local on your PC is different; I had hoped this would solve it. The real solution would be if apcupsd uses the local for the decimal separator, I checked a bit over the weekend but did not see such a configuration in apcupsd (maybe missed it!).
                            Attached is an updated version of the plugin for testing. Based on my testing this should work (I switched my US computer to FR, but their might still be slight differences). Let me know if that resolves the issue; if so I post an updated version to the Updater.
                              Hi Eole,
                              is the plugin working OK now ?
                              I live in Germany and I'm also interested in the APS CS 650.
                              It would be great if it works.
                              Fischi
