Time Left device
  • Time Left device
    I hadn't updated for several versions and did so yesterday.
    I had a couple of events setup that looked at the value of the time left device. They were set to trigger if the value went below 300. After upgrading those events started triggering. I'm pretty sure you were storing the number of seconds as the device value in previous versions. Now the device value is always 0.
    Did this change in newer versions?
    Jeff Farmer
    HS 3, HSPhone
    I check and not intentional, i.e. still want to save the value on the device as the number of seconds.
      I found the issue and a regression I introduced. I sent version 3.1.0.4 to HS for the updater.
        Thank you!
        Jeff Farmer
        HS 3, HSPhone
