APCUPSD HS Plugin Failure
  • APCUPSD HS Plugin Failure
    After downloading the subject plugin, it appears in the list of plug ins with an OK status. The Instance column says to See plug-in config. The config screen is as follows...
    Error: System.InvalidCastException: Conversion from string "60.0" to type 'Integer' is not valid. ---> System.FormatException: Input string was not in the correct format at System.Int32.Parse (System.String s) [0x00000] in :0 at Microsoft.VisualBasic.CompilerServices.IntegerType.FromStrin g (System.String Value) [0x00000] in :0 --- End of inner exception stack trace --- at Microsoft.VisualBasic.CompilerServices.IntegerType.FromStrin g (System.String Value) [0x00000] in :0 at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger (System.String Value) [0x00000] in :0 at HSPI_APCUPSD.HSPI.get_UPSUpdateInterval () [0x00000] in :0 at (wrapper remoting-invoke-with-check) HSPI_APCUPSD.HSPI:get_UPSUpdateInterval () at HSPI_APCUPSD.hspi_config_page.GetPagePlugin (System.String PageName, System.String user, Int32 userRights, System.String queryString) [0x00000] in :0
    APCUPSD on my Win 10 PC installed and configured without a problem and displays UPS status detail when the systray icon is executed.
    Thoughts?
    Bob
    Did you enter 60.0 into the update interval configuration? Can you try to entrr 60 instead of 60.0?
      Phillippe -
      I'm a bit confused...the Poll Time in WINAPCUPSD is set to 60 (not 60.0). I'm not sure if that is what you are referring to or how I get to the "update interval configuration" parameter in the HS APCUPSD plugin.
      Bob
        OK I understand what could produce this. It will be fixed in the next version.
