Plugin changes are coming
  • #16
    I just received an email from Paul about this. He asked if you could try this build:
    http://brultech.com/files/EngineG1.exe
    Let me know how it works. If it does not he said there is more detailed logging.
    Thx
    Cheers,
    Bob
    • #17
      • #18
        I have forwarded on the issue. I will let you know when I hear something
        Cheers,
        Bob
        • #19
          Please try this one:
          http://www.brultech.com/files/EngineG2.exe
          Cheers,
          Bob
          • #20
            The error now has more information it is "Tcp error #9 at location # 20"
            Jim
            • #21
              Jim
              http://www.brultech.com/files/EngineG.exe
              Cheers,
              Bob
              • #22
                Originally posted by Blade View Post
                • #23
                  The TCP error #9 error is gone but there is a new error “HA TCP Port value is invalid”. This error occurs every couple minutes.
                  There is another problem that I am having is that the plug-in becomes disconnected and you need to click the connect button. This can happen when you stop and restart the engine software or sometimes in the middle of the night when nothing is going on.
                  Would there be a way to have the plug-in check at preset intervals and reconnect if need be?
                  I have forwarded your info to Paul. As soon as I hear from him, I will let you know.
                  If the plugin has not received any data from the Brultech Engine in x seconds, it will attempt to reconnect to it.
                  What do you have the "Client Connection Data Timeout" value set to? The default is 60 seconds
                  Cheers,
                  Bob
                  • #24
                    Just upgraded to the latest version of the plugin for my 1220 and am having some problems.
                    When I try to install the "EnginG" software I get a run time error '53': file not found SQLite3VB.dll error
                    Also, do I need to un-install the resident server?
                    Scott
                    • #25
                      I am not using the resident server app anymore.
                      Did you install the full build on their site first and then just replace the EXE with the latest on their site?
                      Cheers,
                      Bob
                      • #26
                        Problem 1 fixed, now onto # 2
                        Now getting a "Device ID of 0 is improper" error.
                        Com Port is open. I can get data from the IA application, but get this error when I select the "Read Device S/N" button.
                        • #27
                          I suggest you contact Paul directly for help on this. I have no control over their Engine application.
                          His email is: brultech@gmail.com
                          Cheers,
                          Bob
                          • #28
                            ________________________
                            Dell Zino HD - HSPRo 2.x
                            HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
                            2 x Brultech ECM1240 with UltraECM
                            USB UIRT
                            Cooper Aspire Z-Wave Switches
                            WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
                            HM ST812-2 Flood Sensor
                            HSM100 - Motion Detector with Light and Temperature
                            2GIG Thermostat
                            BLDSC - Alarm Plug-in
                            BLUPS
                            UltraLog (SQL2008)
                            Jon00 Plugins
                            Host XR3 BT and Jon00 BT Proximity
                            Global Cache IP2IR
                            Foscam FI8918W
                            • #29
                              I would say yes to both.
                              Cheers,
                              Bob
