Can't Connect - Fixed
  • Can't Connect - Fixed
    I have the ECM Engine running on my HS server and it connects Ok to the ECM-1240
    I entered the IP address and port, but cannot connect. I get this in the log:
    ERROR - Caught this exception - No connection could be made because the target machine actively refused it 192.168.168.254:8083
    This is the address of the HSServer where ECM Engine is running and port 8083 is what the Etherport is using to communicate with. Did I get this right?
    Regards
    mark
    ________________________
    Dell Zino HD - HSPRo 2.x
    HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
    2 x Brultech ECM1240 with UltraECM
    USB UIRT
    Cooper Aspire Z-Wave Switches
    WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
    HM ST812-2 Flood Sensor
    HSM100 - Motion Detector with Light and Temperature
    2GIG Thermostat
    BLDSC - Alarm Plug-in
    BLUPS
    UltraLog (SQL2008)
    Jon00 Plugins
    Host XR3 BT and Jon00 BT Proximity
    Global Cache IP2IR
    Foscam FI8918W
    Didn't have forward data to HA plugin turned on
    USB UIRT
    2GIG Thermostat
    BLUPS
    UltraLog (SQL2008)
    Jon00 Plugins
    Global Cache IP2IR
    Foscam FI8918W
