424:Object required error - resetting accumulated values
  • 424:Object required error - resetting accumulated values
    How to use script methods
    i want to track the power usage over last 7 days, so I made 7 virtual devices 9P1-P7), at midnight, I copy 6-77 5-6, etc. I then want to reset the accumulated value on ECM1240
    I tried the following (assuming this works with the 1240):
    Sub Main
        hs.setdevicestring "P7", hs.devicestring("P6")
        hs.setdevicestring "P6", hs.devicestring("P5")
        hs.setdevicestring "P5", hs.devicestring("P4")
        hs.setdevicestring "P4", hs.devicestring("P3")
        hs.setdevicestring "P3", hs.devicestring("P2")
        hs.setdevicestring "P2", hs.devicestring("P1")
        hs.setdevicestring "P1", hs.devicestring("]6")
    hs.plugin("BLPowerMonitor").ResetEcm1220AccumulatedData()
    End Sub
    I get this error:
    424:Object required in line 10 More info: Object required
    Can anyone tell me how to fix?
    Regards
    mark
    ________________________
    Dell Zino HD - HSPRo 2.x
    HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
    2 x Brultech ECM1240 with UltraECM
    USB UIRT
    Cooper Aspire Z-Wave Switches
    WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
    HM ST812-2 Flood Sensor
    HSM100 - Motion Detector with Light and Temperature
    2GIG Thermostat
    BLDSC - Alarm Plug-in
    BLUPS
    UltraLog (SQL2008)
    Jon00 Plugins
    Host XR3 BT and Jon00 BT Proximity
    Global Cache IP2IR
    Foscam FI8918W
    Ah yes. That call will likely not work anymore now that I am using the Brultech engine app to get the data.
    Cheers,
    Bob
      Hi Bob
      Thanks for the reply. So does that mean there's no way in either the plug-in or the engine to automatically reset the accumulated value each night?
      USB UIRT
      2GIG Thermostat
      BLUPS
      UltraLog (SQL2008)
      Jon00 Plugins
      Global Cache IP2IR
      Foscam FI8918W
        I believe you can reset it in the engine app but I do not know how to do it off hand.
        You could contact Paul Brule. I am sure he knows because he wrote the engine app.
        Cheers,
        Bob
