Blade, do you have a Plugin for Current Cost Envi for HS3?
  • Blade, do you have a Plugin for Current Cost Envi for HS3?
    Blade,
    I am a HUGE fan of your code and support. You are my default person that I will purchase from if a plugin exists for what I want.
    I am looking to move from HS2 to HS3 and from what I have read people are very disappointed in the HS3 implementation of the Current Cost Envi hardware. Do you have a plugin that supports the Current Cost Envi power meter?
    While I am in the topic (off topic for this board, but same type of question), do you have a plugin that will log temperature data from sensors and then graph the results (a replacement for mcsTemperature)? Nothing fancy, just log device values to a DB and then graph the results in the DB?
    Thanks Blade,
    Jean-Marie Vaneskahian
    jean@vaneskahian.com
    Jean-Marie G. Vaneskahian
    I do not have a plugin for it. Sorry
    Cheers,
    Bob
      Thanks Bob, anything for the data logging and graphing the temperature sensors?
        Not at this time. I think HS has a plugin for current cost but I am not positive
        Cheers,
        Bob
          Have a look at the Device History plugin this should do what you want.
          Greig.
          Scripts =
          Various
            For the Current Cost Envi, have a look at this plugin: http://board.homeseer.com/showthread.php?t=165447
              Thanks so much for the replies!!!
