Plugin is now in the HS3 updater
This is a sticky topic.
  • Plugin is now in the HS3 updater
    I have a basic plugin up and running for the TED5000
    I wanted to get it into the updater so people with a TED5000 can play with it.
    We can build on it as we go.
    I will let you know once it is in the updater
    Cheers,
    Bob
    The plugin is now in the HS3 updater
    Cheers,
    Bob
      But...
      Jul-23 10:47:40 AM Error Error, Class not found in plugin EXE, maybe namespace is not correct,? Note filename is case sensitive!: HSPI_BLTED.exe Class: HSPI_BLTED.HSPI
      Jul-23 10:47:40 AM Updater Install/Update of package BLTED was successful.
      Jul-23 10:47:40 AM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_BLTED.exe.config
      Jul-23 10:47:40 AM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLTED\Images\historyPage.jpg
      Jul-23 10:47:40 AM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLTED\Images\maintainGatewaysPage.jpg
      Jul-23 10:47:40 AM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLTED\Images\optionsPage.jpg
      Jul-23 10:47:40 AM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLTED\Images\webInterface.jpg
      Jul-23 10:47:40 AM Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLTED\BLTED_Help.asp
      Jul-23 10:47:40 AM Updater Installing package BLTED
      Jul-23 10:47:40 AM Updater Update HSPI_BLTED.exe downloaded successfully
      Jul-23 10:47:37 AM Updater Downloading update: BLTED
      Jul-23 10:47:37 AM Updater Starting download of updates
        That is odd. It is running here with no issues
        The HSPI class is definitely in the code
        Try restarting HS3
        Cheers,
        Bob
          I got it to work by renaming the EXE to hspi_BLTED. Looks like you've defined the class internally to lowercase hspi_BLTED?
          Z
          Note:
          Curiously, once HS3 recognizes it, you can rename the file back to the Uppercase version.
          Looks good so far.
          Z
            Yea my bad
            I have renamed it to HSPI_BLTED.exe for the next release
            Cheers,
            Bob
              Try 1.0.5 and let me know if it is fixed
              Cheers,
              Bob
                That did it. Installed without a problem.
                Z
                  I have posted 1.0.6 to the HS3 updater
                  - You can now specify the number of history records to return for each of the 5 history reports.
                  - You can edit these values when maintaining a gateway.
                  Cheers,
                  Bob
                    Any screen shot of BLTED yet Bob?
                    Hector
                    Win.2003 OS, HS3
                    MyTrigger,ACRF2,W800,Zwave
                    AP800,Honeywell Stat
                      Have you looked in the HS store?
                      It has been there for quite some time
                      Cheers,
                      Bob
