WARNING: Failed getting InterfaceStatus from Current Cost
  • WARNING: Failed getting InterfaceStatus from Current Cost
    Hi!
    I have tried to get the current cost plugin working with HS3 Pro Edition 3.0.0.368 (Windows). I am running a windows 10 installation on a virtual machine and I have tried both the release available currently as well as the beta version (3.0.0.35) Both fail with this error message:
    WARNING: Failed getting InterfaceStatus from Current Cost - the interface was not found in the list of active interfaces, the list may need to be refreshed.
    The logs shows this:
    HTML Code:
    feb-25 17:38:46	 	Plug-In	Finished initializing plug-in Current Cost
    feb-25 17:38:46	 	Error	Initializing plug-in(2): Current Cost Instance::Conversion from string "0.13" to type 'Single' is not valid.STACK: Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
    feb-25 17:38:45	 	Info	Plugin Current Cost has connected. IP:127.0.0.1:50830
    feb-25 17:38:36	 	Updater	Install/Update of package HomeSeer CURRENTCOST ENVI was successful.
    feb-25 17:38:36	 	Updater	Copying file: C:\Program Files (x86)\HomeSeer HS3\Bin\CurrentCost\SQLite.Interop.dll
    feb-25 17:38:36	 	Updater	Copying file: C:\Program Files (x86)\HomeSeer HS3\Bin\CurrentCost\System.Data.SQLite.dll
    feb-25 17:38:36	 	Updater	Copying file: C:\Program Files (x86)\HomeSeer HS3\html\CURRENTCOST\Help.htm
    feb-25 17:38:36	 	Updater	Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_CURRENTCOST.exe.config
    feb-25 17:38:36	 	Updater	Installing package HomeSeer CURRENTCOST ENVI
    feb-25 17:38:36	 	Updater	Update HSPI_CURRENTCOST.exe downloaded successfully
    feb-25 17:38:34	 	Updater	An item in the Updater is temporarily unavailable: The operation has timed out Item: https://dl.dropbox.com/s/s1mpzz5poizkzud/updates.txt
    feb-25 17:38:30	 	Updater	Downloading update: HomeSeer CURRENTCOST ENVI
    feb-25 17:38:30	 	Updater	Starting download of updates
    Anyone worked out a solution for this?
