Default Rate
    Default Rate
    The default rate stays .13 no matter what I do to change it. I have tried creating a table with that rate for all fields but the plugin is not using .17. I even changed it manually in the currentcost.ini file for default to be .17.
    Any ideas?
    The default rate never changes, the plugin uses the tables rates. This is a bit confusing but as long as the table shows the correct rate you should be set.
      I have the same problem
      You say that the table rates are used in calculations and displays? But why is the Device Name 'Energy Cost Per KWH' always showing 0.13? When I read this device using a script with the DeviceValue function I always get 130?? I need ro read the rate reading that I have set. Is this possible?
        Does anyone know the answer to the question above? I'm seeing the same behavior. Even though I changed all of the rates in the grid on the config screen, the device still shows .13 for the Energy Cost Per KWH.
          See the note. (Used when creating a new table, or for any values in the rate table that are blank.)
          otherwise the values in the tables are used.
            Ok so the device is displaying the default value. Now I'm clear. Thanks.
              Actually it turns out that I had to update the default table rather than creating a new rate table. Once I did this the Energy Cost Per KWH device showed the proper value.
                I also uncovered what I think is a bug in the plugin. If I select a different rate table and then restart homeseer, it reverts back to the default table.
                  I know it's been over a year but i just got the envi device. I'm seeing the same thing. My custom tables are ignored and the default is always used. Is this a bug? Anybody else out there using this? Thanks.
                    Ok, i just confirmed that this is a bug. The only way to change the table used is to go to the ini file and change it there, then restart HS. Works fine like that.
                      Be sure to submit a helpdesk bug report ticket
                      At the top of the screen hover on "Support" then click on "Report a bug". Otherwise HS won't know to fix it.
                      Steve
                      (System configuration is in my profile)
