Hi
I have just ordered an ENVIR, two extra clamp modules, and 6 IAM plug in modules. I run HSP on Windows XP SP3 and I live in the UK.
I would like to use the ENVIR plug in modules to detect when certain devices are running. As an example I have a new dishwasher and I'd like to detect when it is running but as the unit is new I do not want to open the device up to connect anything to it to detect when it is running. My plan is to connect the dishwasher via an ENVIR plug in module and this will allow me to monitor to current consumption of the dishwasher and therefore tell HS if it has been powered on and is working.
I will also use 3 clamp on leads on one ENVIR transmitter to detect the power consumption of various ring main circuits in the house. I have plenty of room in my fuse box to attach the clamps to the live wires that feed the circuits I wish to monitor. I would like to trend this clamp data, though I may use Jon00s excellent graph script for this as I do not want lots of new devices creating for this function, which might be the case if I understand the forums correctly.
I have read through the forums about using the HS plugin and also Mr. Happy's script. What is the consensus as to what HS in interface is the best to use? I've read that there are CPU usage issues with the HS plugin and that is also creates many devices. I only need a device per sensor to show the current power consumption of the unit so I can write some code to check for changes, I do not need graphing facilities. it looks like Mr. Happy's script would be best for this but as I've not used either method yet I'd like some feedback on which method most people use. Can Mr. Happy's script use 3 CT clamps on one transmitter? I think the HS plugin can.
