How to begin?
    How to begin?
    Hello.
    I have bought from Homeseer Envi Current cost.
    I have bought plugin, and i have installed it correctly on my Hometroller.
    Ok. And now, what do i have to do?.........
    I have found no instructions about. Can i import some devices?
    Where can i see data from Current cost in Homeseer?
    Thank you
    Did you enalbe and configure the plugin?
    -Rupp
      I have obviously enabled the plugin, but i don't know how to configure it.
      I suppose i have to 'import' devices, as for the other plugin, but i ignore how to do this......
        No there is nothing to import. There should be a new link on your HS web interface name Current Cost History. This will show you the graphs. There should also be a several new devices listed under the Current Cost Main Sensor.
        -Rupp
          When you enabled the plugin, there should be a configure button directly under the enable button.
            In the 'configuration screen' of the plugin, i can see the parameters about hours/cost, but nothing more.
            I need to import the devices, in order to have the screen reporting a device code with a value.
            How can i do?
              How can i do?
              The plugin automatically creates about 20 new devices. Did you go to the status page and select the Current Cost Main Sensor?
              -Rupp
                In the status page, i have checked 'sensor 1' in the 'remote trasmitter' tab. Is this the current cost main sensor?
                  I can see the new link and the graph, but the graph does not report any value and i can not see the 'current cost main sensor' and the new devices....
                    Attached is a screen shot of how I have mine configured.
                    I'm in the UK and just have the one sensor, not sure if it will be the same for you.
                      .......the problem was really simple and now i have solved this......
                      I connected Envi to usb port com3 and everything on Homeseer startup was fine, but it was not so!...
                      Changing com port randomly, i arrived to com port 9 and Homeseer, then, recognized Envi and created devices.......
                      Now i have everything working ok.
                      Thank you all for your intrest and scuse me for my bad anglish and for my bad experience in Pc......
                        So I installed my Envi and plugged it into the USB port and installed the proper USB port. I see it on com port 4. Power readings at the hand held look good.
                        I went to the updater and installed the plugin. I rebooted Homeseer and the Genuine plugin thing came up, and I installed the plugin.
                        I go to the setup page, and I don't see the envi plugin anywhere. No config page, no enable button-- Nothing. I see my other plugins there (HS touch, etc).
                        Any ideas? I have Homeseer installed on my D drive so I am wondering if there is a drive letter bug in the plugin. I've seen several where the assumption is everything is on C...
                        Plug-Ins Enabled:
                          Are you running HomeSeer as a service?
                          -Rupp
