Originally posted by Mark42
View Post
Database size question.
David Bott
Well I do get the charts, just not monthly totals. And you are right, sometimes I get the chart, and other times I do not. But I surely do not get the totals even when I get the chart to show.
I really wish this thing would be fixed. It has been far to long of a wait.
A little before and after.
As you can see the little HT2 was really struggling with History.DB at 91MB. After a quick shutdown, rename, and HS restart, the system response is amazing. It was deteriorating so slowly over time that I didn't realize it.
Another ENVI specific metric, the calculated tags like ^12, Actual Usage This Month (KWH), are now updating every ~90 seconds. Prior to restarting the with a null database, it was taking ~118 seconds between updates.
Mark
David Bott
I am guessing the bottom chart is after the restart. I surely can see the major hit in the CPU, but it is funny for if you look at the CPU use, it is lower on chart 1 at 2% vs 24%. So if you look at that, things could see worse.
(I know that is CURRENT CPU use. But found it funny.)
What I'd like to know is why does it peg the cpu to 100% at regular intervals. Surely inserts can't be totally responsible here ???
I see the same pattern in my system.
RobertHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
... about 90MBHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
David Bott
