Reading Main Sensor Actual Usage - Today(KWH) - Solved!
  • Reading Main Sensor Actual Usage - Today(KWH) - Solved!
    I would like to read the Main Sensor Actual Usage - Today(KWH) at 11:59pm each day to the hs log file so that I can then use Ultralog to create a custom report. Question is... is the value of `11 device a string or floating point number? Any suggestions on doing this?
    Rob
    Edit: Ok... a second cup of coffee and I see this works...
    & hs.writelog "Usage",hs.devicestring("`11")
