CurrentCost plugin beta 1.0.0.60
    Some fixes to the graphs in this version.
    Download the DLL here:
    This update is on hold for now.
    Current Cost PLug-in SQL error mesage in log
    Installed current cost plug-in yesterday, all of the data being stored looks ok and reflects correct consumption. Log is (endlessly) repeating displaying this error:
    1/13/2012 8:00:09 AM Current Cost Error, SQL Exception adding record to the Temperature table of the history database: SQLite errorno such column: Infinity, Code=Error, Link=
    1/13/2012 8:00:09 AM Current Cost An attempt to add the weather device value of Infinity failed
    Attachments contain the plug setup and the homeseer system information. Tried beta 58 and 60 no change.
    any sugesstions?
    thanks
    -rick
    -Rick
      I set the device value divisor (using config button for the plug-in) field to 1 as the default was a 0. After a few minites the log errors stopped and have not returned for more than 30 minutes.
      To confuse things a bit I had also set the logging level to debug prior to the above so I don't know if that had anything to do with resolving the log error or not - probably not, but who knows....
      -rick
      -Rick
        I set my update to 2 minutes....Data for today v's yesterday looks wrong
        HS3 Pro Edition 3.0.0.435 (Windows 10 vmware)
        BLOccupied:,UltraNetCam3:,weatherXML:,RFXCOM:,Current Cost 3P:,UltraGCIR3:
        DMMQTT:,Kodi:,Z-Wave:,BLRadar:,EasyTrigger:,MySensors:,BLBackup:
          Can you elaborate a bit or better yet post an image and articulate what you see as the issue?
          -Rupp
            I would delete the old database and start fresh, that is what I did. When you change the save interval it may be messing up previous calculations.
              Rupp here is an example.....look at hourly 1.5 ish look at today v yesterday 4 ish....
              Rich did rename the db and restart lets see how it goes.
              thanks.
              Dan
                I just switched back to previous version, even after deleting database the today vs yesterday was way too high consumption....
                  I got the same thing... I was about to attach my file - but it looks the same. When the house was using a mere .5 kwh, the pluing reported a spike of over 4 kwh...
                    I am looking into it, something is obviously not correct.
                      It will take a little time to get this fixed up, so for now, go back to the plugin that is in the updater. I will post an update when I have a fix.
