My device stopped sending data to HS. I tried to unplug it see if it cleared. I also reset the plug in, checked the com port as well. The main device is receiving the signal from the breaker box. Any ideas?
Stopped sending data
Its worth opening the port in Hyperterminal (57600,N,8,1 IIRC), without any configuration it will send data out every six seconds and you can see the XML output. Current Cost have a utility on their website that does this aswell (C2 Terminal I think), that will show whether it is a problem with HS or data is never getting to the PC.
