Temperature in Config
    Can someone tell me what the "Outside Temperature" does or where it shows up when configuring it for this plugin?
    In the config screen, you can select the Current Cost Temperature for logging or not.
    You do this after the devices are created for the Current Cost.
    72 Z-Wave Nodes, 111 Events, 422 Devices
    Z-Wave, UPB, WiFi
    Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
      Does anyone know what it does? I am guessing it gets logged but I don't see it showing up in charts, etc. What do I use it for?
        I watch this temp to see how hot my wiring closet gets as this is where my display unit is located.
        -Rupp
          Rupp, I'm confused. There is the temp that's on the current cost unit that shows up as a HS device. I am not referring to this one. I am referring to the setting in config that asks for an outside temperature device to log. I have one identified but I don't know where the plugin is using it and don't see any guidance in the help files.
