Trigger on hi usage?
  • Trigger on hi usage?
    I want to trigger even on exceeding a certain power KW.
    I assume us conditional of "In the range of nn...nn".
    However KW output Scales in watts, then KW as Value exceeds 1000 wats.
    How do I act upon a numerical watt value if the addin returns number + text of wats or KW?
    Device values can not store text. Did you check the deviceValue of the device in question?
    -Rupp
      Can't you just add the extra three zeros to the range?
      If you want to trigger on usage higher than, say 10 kW, you put would put the range to "10...100". Now you just put "10000...100000" for example.
        I know you can use scripting to do this, if thats an option for you:
        PHP Code:
        If (CInt(hs.DeviceValue("A1")) >= 3000 And CInt(hs.DeviceValue("A1")) < 7000Then
        ''do something
        End
        If
        Replace A1 with the device code for the Realtime Usage All Channels(KW)
          Thanks rmasonjr. Your code snippet put me on the right track.
          Phil
            Phil
            No problem. I use this particular scripting to change font colors on my HSTouch display based on kW values. If my family sees green on the display, then the kW are below 3kw. Yellow is 3kW - 7kW. Red is anything above 9kW. Dad gets progressively irate based on the colors
