I'm interested in this, but am not sure what hardware to buy for interfacing with HS and this plugin. It's pretty clear that I need the EnviR display and seems like I also need the serial to USB cable. Then, I'll need the CT clamp to monitor whole-house. Is that it?
As best I can tell, the EnviR display is connected to the HS PC via the serial to USB cable and passes all the receiver data it gets. Now, what about the Individual Appliance Monitors? If I have one EnviR display with the CT clamp plus a couple IAMs linked to it, the EnviR will be able to transmit all the data to the HS plugin with no additional hardware needed? According to the plugin description, "The Envi monitor allows up to 10 transmitters, each with up to 3 sensors connected to it." So, I'm assuming the transmitter for the CT clamp is 1 and each IAM would be an additional "transmitter" reporting to HS. Correct?
And finally, where to purchase? I see that HS has a unit or two available. There's also a US distributor - PowerSave (www.currentcost.net). Has anyone bought from PowerSave?
