FRESH install of HS2 on a fresh XP SP3 machine. Loading up plug-ins one at time. Got to Current Cost and everything looked like it installed. Enabled it in Setup, config'd it......all looked good. Went to Status and there are no devices. No Events either. Web page there but no data.
Tried process several times. Every time it goes without error. HS seems to be connecting/seeing ENVI on com4. ENVI is communicating with the sensor.
Any ideas why the devices and events don't load? Do I need the Include files perhaps? ????
SOLVED! POS cable..... It worked fine on my old machine. Would not work on new machine. Put it back on the old one and it works SOME of the time. Bad connection within the cable........
