Error: Could not process response. : implement me: Erl
  • Error: Could not process response. : implement me: Erl
    I am testing HS3 (3.0.0.163 Linux), Current Cost (3.0.0.35), the plug in was running very well for about 2 days then started producing the following error every 1:10 or so.
    May-21 7:46:29 AM Current Cost Error: Could not process response. : implement me: Erl
    Any ideas?
    The plug in stills seems to be working, just filling my log with the message and consuming large amounts of CPU.
    Sadly MrHappys Plugin is not available for Linux
    Any ideas?
    I'm seeing the exact same thing. Did you ever get any feedback or figure anything out on your own?
      I'm still seeing this error in the logs every 2 minutes or so.
      Oct-01 9:10:04 AM Current Cost Error: Could not process response. : implement me: Erl
      I'm not 100% sure, but at least it seems that while CPU utilization more than doubles with CC plugin enabled, it doesn't completely make my RPi2 unusable like previously. So I've kept the plugin enabled for now. I show about 2 cores of 4 fully utilized. Usually it's 1 or less.
      I'm now on HS3 Linux .205.
        Same issue here.
        Raised a Bugzilla 3007 on 22nd September 2015 but no reply yet.
        Oct-10 16:59:09 Current Cost Error: Could not process response. : implement me: Erl
        Oct-10 16:57:26 Current Cost Error: Could not process response. : implement me: Erl
        Oct-10 16:55:47 Current Cost Error: Could not process response. : implement me: Erl
        Oct-10 16:54:06 Current Cost Error: Could not process response. : implement me: Erl
        Oct-10 16:52:25 Current Cost Error: Could not process response. : implement me: Erl
        Have uninstalled re-installed tried several options but still the same.
        HS2 on Dell PC
        HS3 on Dell PC with Mr Happy's Currentcost Plug-in.
        HS3 on Raspberry: HS3 ZEE S2 Edition 3.0.0.208 and CurrentCost Plug-in
        Jo
          Same situation here,
          HS3 on Raspberry: HS3 ZEE S2 Edition 3.0.0.183 and CurrentCost Plug-in BETA 3.0.0.35
          Apr-26 12:28:52 PM Current Cost Error: Could not process response. : implement me: Erl
          Apr-26 12:27:33 PM Current Cost Error: Could not process response. : implement me: Erl
          I'm receiving continously these messages and the CPU is raising.
          I've created a Bugzilla Report (3256) with no success. Nobody is answering. In theory is assigned to wade@homeseer.com but there was no answer yet...
          It's absurd that a HomeSeer Plugin has no support at all.
