Looking for CCHSTouchChart.vb
  • Looking for CCHSTouchChart.vb
    Hi, i am trying to get the current cost charts in hStouch. The post ( see http://forums.homeseer.com/showpost....&postcount=264) describes using jonshtml to image and also CCHSTouchChart.vb.
    However i cant find the link to download the script.
    Can anyone help?
    regards
    It is just a link to the http Energy page. Use that link into your hstouch and you should be all set.
    Sent from my SM-G935V using Tapatalk
      Can anyone help?
      regards
      Check the post again and if by magic it should be back. I'm terrible at deleting the attachments without looking correctly, I've included it in the main plugin file for the next release.
      My Plugins:
      Yeelight 3P | Nanoleaf 3P
        Hello Mr.Happy
        I use the script CCHSTouchChart.vb from lot of time and until May 2017, it worked very well but now I see that the script doesn't work more. I don't know what the reason is. In the directory C:\Program Files (x86)\HomeSeer HS3\html could be the files updates but these files have the date of May 2017. Now when I run manually the script, it does not create the files html like before. In the last period homeseer has developed some new versions and now I use the version 3.0.0.368. In attached the file CCHSTouchChart.vb that I used. Is there new version of this script?
        Massimo-RenderCAD
        _________________
        HomeSeer Version: HS3 Pro Edition 3.0.0.368
        Operating System: Microsoft Windows 7 Professional - Work Station
        Number of Devices: 381,Number of Events: 231,Available Threads: 200
        Enabled Plug-Ins
        3.0.0.29: ADIO-100
        1.0.0.85: Arduino Plugin
        2.0.3.0: BLDatabase
        3.0.14.0: BLMediaPlayer
        2.0.5.0: BLVolume
        0.0.0.42: Current Cost 3P
        0.0.0.3: Device Comparison 3P
        1.2.0.0: Device History
        3.0.0.33: EasyTrigger
        5.0.0.58: Global Cache Pro
        3.0.0.14: NetCAM
        3.0.1.90: PHLocation
        1.0.0.5: Restart
        3.0.0.21: VWS
        3.0.1.130: Z-Wave
          Originally posted by RenderCAD View Post
          Hello Mr.Happy
          Massimo-RenderCAD
          _________________
          Enabled Plug-Ins
          3.0.0.29: ADIO-100
          2.0.3.0: BLDatabase
          2.0.5.0: BLVolume
          3.0.0.14: NetCAM
          1.0.0.5: Restart
          3.0.0.21: VWS
          3.0.1.130: Z-Wave
          The file in the attached script has a couple of lines that are commented out (they start with the ' symbol), these prevent the files being created. If you remove the four ' symbols on the four lines which end with the My.Computer line then try it again it should create the file.
          My Plugins:
            Hello Mr.Happy
            Now the script works well
            Many thanks
              How do you implement this?
              Robert
