Using Replacement Variables
  • Using Replacement Variables
    I'd like to setup an event that triggers at a certain usage limit and then sends me a message. In the message I'd like to quote the value using $$DVaddress) however none of the devices for this plugin have an address value set. If I add the address manually I'm not able to use $$DV: to display the value. Any idea how to fix this, can you set the address value when the plugin is installed?
    Click image for larger version  Name:	Capture6.JPG Views:	1 Size:	22.5 KB ID:	1282730
