Hey,
I have Fronius Primo inverters, hoping this plugin would work with them as well I tried it, and it worked, kind of.
It seems to be only reporting the generation from my first inverter. I have 3 inverters on my system, with a single data card. All 3 inverters tie into the first, and it reports on all of them.
Is there any way that I can get the plugin to report the total generation of all 3 inverters? Or even if it showed all 3 individually? Or is it just setup for single inverter systems? Thanks,
EDIT: I should have looked closer at the plugin before posting. I think "Current Feed Into Grid" is the total production between all 3 inverters, while "Current Generation" is only for the one with the data card installed. Doesn't seem to show inverters 2 and 3, although that probably doesn't matter much to me really.
