Addition of current reading for L1, L2 and L3
    Hi Stefan,
    I have a 3-phase system. Is it possible to add the readings of the current for L1, L2 en L3. In this way it is easier to see how the system is balanced throughout a longer period.
    John
    Probably, if the meter provides that information. I have a three-phase system and my P1 port doesn't reveal that info.
    stefxx
      I own the Sagecom T210-D smart meter.
      According to this article a lot more info can be retreived from this meter as your PI is currently reading out.
      I don't ask to implement everything. Although that will be nice and I don't think this is a lot of additional work
      But the current readings (and maybe also the voltage) will fit for my purpose.
      John
        Can you enable "Log Received data (raw)" in de config and send me the info shown in the event log? Then I will have a look at it, time permitting.
        Or maybe something to consider for a HS4 version...
        stefxx
          Hi Stefan,
          See below the log (i did hide the meter ID). As you can see a lot of parameters are reported.
          Looking forward to the implementation, would be nice if it could be in the HS3 PI.
          But a (paid) HS4 version is also OK for me.
          John
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:62.7.0(00.000*kW)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:42.7.0(00.240*kW)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:22.7.0(00.000*kW)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:61.7.0(00.072*kW)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:41.7.0(00.000*kW)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:21.7.0(00.097*kW)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:71.7.0(002*A)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:51.7.0(001*A)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:31.7.0(001*A)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:72.7.0(227.0*V)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:52.7.0(226.0*V)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:32.7.0(225.0*V)
          3/02/2020 14:33:27 Legacy-Plugin P1 0-0:96.13.0()
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:72.36.0(00000)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:52.36.0(00000)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:32.36.0(00000)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:72.32.0(00002)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:52.32.0(00002)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:32.32.0(00002)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:99.97.0(1)(0-0:96.7.19)(180920045725S)(0000000205*s)
          3/02/2020 14:33:27 Legacy-Plugin P1 0-0:96.7.9(00005)
          3/02/2020 14:33:27 Legacy-Plugin P1 0-0:96.7.21(00658)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:2.7.0(00.240*kW)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:1.7.0(00.169*kW)
          3/02/2020 14:33:27 Legacy-Plugin P1 0-0:96.14.0(0002)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:2.8.2(002404.663*kWh)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:2.8.1(001016.579*kWh)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:1.8.2(004066.546*kWh)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-0:1.8.1(005945.886*kWh)
          3/02/2020 14:33:27 Legacy-Plugin P1 0-0:96.1.1(**************)
          3/02/2020 14:33:27 Legacy-Plugin P1 0-0:1.0.0(200302143303W)
          3/02/2020 14:33:27 Legacy-Plugin P1 1-3:0.2.8(50)
          3/02/2020 14:33:27 Legacy-Plugin P1 /Ene5\T210-D ESMR5.0
          3/02/2020 14:33:17 Legacy-Plugin P1 !65DA
            Thanks!
            I will put in on my todo list. Don't expect anything soon.
            stefxx
              Thanks!
              Thnx for the update
              John
                Hi John,
                I choose to skip this request and create a complete new Smart Meter plugin for HS4. I migrated nothing, started from scratch. It should be released into the updater in the next few days. It is a paid version, and no devices will be migrated due to the totally different approach of this plugin. This also means this plugin can be tested and you can always go back to the previous (free) version without issues with devices.
                The good news is that is supports both P1 (USB/Serial) and network (ie ser2net) connections, and that I have implemented the complete DSMR 3, 4 and 5 standard, so every attribute (that is supported by the connected smart meter) should be fully included. Also, it supports an unlimited number of smart meters, also remotely (by using ser2net).
                As this is a complete rewrite, there could be some bugs. Let me know if you catch any!
                stefxx
                  Hi John,
                  Hi Stefan,
                  This is great news. Will test when available.
                  John
