error 2 reading data: Object reference not set to an instance of an object.
  • error 2 reading data: Object reference not set to an instance of an object.
    Hi Rien,
    Recently I have been moved to another house.
    My new home does also have a smart meter with P1 port.
    After installing the Smile P1 the plug-in the following error occurred
    Error 2 reading data: Object reference not set to an instance of an object.
    mrt-06 19:12:58	 	Plugwise Pro	Smile P1 error 2 reading data: Object reference not set to an instance of an object.
    mrt-06 19:12:58	 	Plugwise Pro	PollSmileP1: Query=http://192.168.2.92/update/firmware
    mrt-06 19:12:58	 	Plugwise Pro	Smile P1 information retreivement -- Smile P1 firmware = 2.1.13
    mrt-06 19:12:58	 	Plugwise Pro	PollSmileP1: Query=http://192.168.2.92/core/modules
    mrt-06 19:12:56	 	Plugwise Pro	Smile P1 information retreivement -- Smile P1 vendor model = KFM5KAIFA-METER
    My current house does not has a gasmeter anymore but 'stadsverwarming' . Could this be causing this issue: the plugin is look for a gasmeter which is not there?
    Bart
    I had the exact problem , when i checked my smile it was broken somehow.
    I got a New one from plugwise and got broken again.
    But when i Disable the plugwise smile tab , the plug-in runs 100% at the last homeseer version...
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.1.18 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
