Daily usage + Log problem
  • Daily usage + Log problem
    Hi rien
    i just tested your plugin , the first thing i want to ask if its possible to see the daily power usage in a device ? also for the gas so i can reset it ?
    or maybe a script . i use the p1 smile so i can keep track of my power usage..
    Also i have a question about logging , i always see this in my log , but debugging is disabled its coming every second..
    PHP Code:
    Sep-14 10:39:27         Plugwise Pro    Smile P1 information retreivement --Smile P1 unit Wh
    Sep
    -14 10:39:27         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total offpeak electricity consumed
    Sep
    -14 10:39:21         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total peak electricity consumed
    Sep
    -14 10:39:21         Plugwise Pro    Smile P1 information retreivement --Smile P1 unit Wh
    Sep
    -14 10:39:21         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total offpeak electricity consumed
    Sep
    -14 10:39:16         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total peak electricity consumed
    Sep
    -14 10:39:16         Plugwise Pro    Smile P1 information retreivement --Smile P1 unit Wh
    Sep
    -14 10:39:16         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total offpeak electricity consumed
    Sep
    -14 10:39:11         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total peak electricity consumed
    Sep
    -14 10:39:11         Plugwise Pro    Smile P1 information retreivement --Smile P1 unit Wh
    Sep
    -14 10:39:11         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total offpeak electricity consumed
    Sep
    -14 10:39:05         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total peak electricity consumed
    Sep
    -14 10:39:04         Plugwise Pro    Smile P1 information retreivement --Smile P1 unit Wh
    Sep
    -14 10:39:04         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total offpeak electricity consumed
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.1.18 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    Anyone know if this is normal ?
      I have to check this.
      Rien du Pre
      The Netherlands
      Using:
      Homeseer PRO latest HS4 BETA on a Raspberry
      Plugin's:
      RFXCOM, mcsMQTT, Z-Wave
        Thanks because its spamming my log
          hi rien
          did you check it ?
          its still spamming my logs every second...
          PHP Code:
          Oct-10 12:34:27         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total peak electricity consumed
          Oct
          -10 12:34:27         Plugwise Pro    Smile P1 information retreivement --Smile P1 unit Wh
          Oct
          -10 12:34:27         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total offpeak electricity consumed
          Oct
          -10 12:34:21         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total peak electricity consumed
          Oct
          -10 12:34:21         Plugwise Pro    Smile P1 information retreivement --Smile P1 unit Wh
          Oct
          -10 12:34:21         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total offpeak electricity consumed
          Oct
          -10 12:34:16         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total peak electricity consumed
          Oct
          -10 12:34:16         Plugwise Pro    Smile P1 information retreivement --Smile P1 unit Wh
          Oct
          -10 12:34:16         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total offpeak electricity consumed
          Oct
          -10 12:34:10         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total peak electricity consumed
          Oct
          -10 12:34:10         Plugwise Pro    Smile P1 information retreivement --Smile P1 unit Wh
          Oct
          -10 12:34:10         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total offpeak electricity consumed
          Oct
          -10 12:34:03         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total peak electricity consumed
          Oct
          -10 12:34:03         Plugwise Pro    Smile P1 information retreivement --Smile P1 unit Wh
          Oct
          -10 12:34:03         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total offpeak electricity consumed
          Oct
          -10 12:33:58         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total peak electricity consumed
          Oct
          -10 12:33:58         Plugwise Pro    Smile P1 information retreivement --Smile P1 unit Wh
          Oct
          -10 12:33:58         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total offpeak electricity consumed
          Oct
          -10 12:33:53         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total peak electricity consumed
          Oct
          -10 12:33:53         Plugwise Pro    Smile P1 information retreivement --Smile P1 unit Wh
          Oct
          -10 12:33:53         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total offpeak electricity consumed
          Oct
          -10 12:33:47         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total peak electricity consumed
          Oct
          -10 12:33:47         Plugwise Pro    Smile P1 information retreivement --Smile P1 unit Wh
          Oct
          -10 12:33:47         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total offpeak electricity consumed
          Oct
          -10 12:33:47         FileControl    Automatic File Control is Updated
          Oct
          -10 12:33:42         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total peak electricity consumed
          Oct
          -10 12:33:42         Plugwise Pro    Smile P1 information retreivement --Smile P1 unit Wh
          Oct
          -10 12:33:42         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total offpeak electricity consumed
          Oct
          -10 12:33:37         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total peak electricity consumed
          Oct
          -10 12:33:37         Plugwise Pro    Smile P1 information retreivement --Smile P1 unit Wh
          Oct
          -10 12:33:37         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total offpeak electricity consumed
          Oct
          -10 12:33:36         CPUTemp    Cool 55C
          Oct
          -10 12:33:31         Plugwise Pro    Smile P1 information retreivement --Smile P1 description Total peak electricity consumed
          Oct
