i've got 9 plug's (from appr. 2009) that can be controlled via source software and now used by HS2 but want to convert to HS3.
Is it possible to use these plug's with HS3?
edwin
edwin
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
ATTENTION INSTEON HUB USERS: We can get you going again! Learn More Now
