Rainforest Eagle plug-in - User Guide
This topic is closed.
This is a sticky topic.
    This plugin is designed to interface Homeseer with Rainforest Eagle energy monitoring gateway for smart meters. It supports both the legacy gateway (EAGLE-100) and the EAGLE-200
    INSTALLATION / CONFIGURATION
    System Requirements:
    This plugin is for HS3 or HS3PRO. It works with both Windows and Linux versions.
    Plugin Installation:
    Download and install from the updater (Energy Management section)
    Plugin Configuration:
    Go to the config page "PLUG-INS > RainforestEagle > Config ", select your gateway type, then enter the username and password you use to log into the cloud portal.
    Click image for larger version  Name:	config.png Views:	1 Size:	48.2 KB ID:	1249903
    For the Legacy EAGLE gateway you will also need to enter your Cloud ID which is the last 6 alpha numeric characters of the Ethernet MAC address of your gateway. You can find it in the cloud portal, in settings > Internet.
    Click image for larger version  Name:	macadress.png Views:	1 Size:	41.8 KB ID:	1249904
    If you want to connect locally to your Legacy Eagle rather than through the cloud, choose Legacy EAGLE - Local. For this to work you will need to disable local security. Log into the local web portal of your gateway, click the down arrow next to date, at the bottom of the page click the gear, and uncheck the security box:
    Click image for larger version  Name:	webportal2.jpg Views:	2 Size:	67.1 KB ID:	1282237
    then fill in the Mac ID field in the config page with the Zigbee Mac 16 alpha numeric characters.
    Click image for larger version  Name:	macid.png Views:	2 Size:	158.0 KB ID:	1282238
    FEATURES
    Devices
    On first run the plugin will automatically create a set of devices: Instantaneous demand, Meter readings from/to Grid, and price.
    Energy screens:
    The plugin also import data to the HS Energy DB so that you can use the Energy web page to graph Usage and Cost.
    The graphs are also available from the HSTouch energy screen:
