Release 4.0.17.0, 19-09-2023
- New: Heat meter (GJ) added
- Imp: Thread handling and serial/ser2net (re-)connecting
- Fix: Electricity H/D/W/M/Y feature creation without electricity readings
- Fix: Fake mode
- Fix: Add new system with Norwegian date/time format
- Fix: “Do not set Image directly” error
- Imp: Allow device name change
- Fix: Events not triggering on some value changes
- Fix: Energy logging configuration
- Fix: Hourly/Daily/Weekly/Monthly/Yearly rollover display status
- New: Hourly/Daily/Weekly/Monthly/Yearly for gas readings
- Imp: Performance
- New: Categories
- Fixed: Watt unit after plugin restart
- New: Improved cumulative/max feature naming
- New: Select fixed Watt unit or dynamic
- Fixed: Max consumed/produces values
- New: kW(h) to W(h), kW(h), MW(h) and GW(h) dynamically
- Fixed: multiple meters
- New: Support for SolarEdge plugin features
- Fixed: kWh -> kW
- Fixed: irregular Value and Status updates
- Fixed: “Next” and “Previous” reversed in log device
- New: max consumed/produced values
- Fixed: broken support link
- Fixed: Energy Direction and Appliance Type in device properties
- Fixed: "HSTouch Server Warning" log messages
- Fixed: startup crash
- Initial version, complete rewrite of the old P1 plugin
- Supports both USB (serial) and network connections
- Supports DSMR standard upto 4.2.2 / 5.0.2
- Supports most older smart meters as well
- All standard DMSR data included (actual data depends on your smart meter)
- Note: old P1 devices will NOT be migrated, please remove them manually
