Hi Stef,
I have an issue with sending device values that have a unit kW or kWh to InfluxDB 2.x using mcsMQTT.
Values for features such as instantaneous voltage, Instantaneous current, Tariff indicator electricity are correctly send to InfluxDB 2.x using mcsMQTT.
I did some troubleshooting with Michael McSharry and my conclusion is that the issue is limited to the values that have a unit kW and kWh.
Michael McSharry indicated that I need to determine why HS is not reporting via HSEvent that 1220 (actual electricity power consumed (in kW) has a Value that has changed. I think that you as plug-in author should be able to give more insight into that. And I hope that you are able and willing to solve this issue.
John
John
