Trouble adding smart meter
    Hi,
    I am having trouble adding a smart meter (Landis+Gyr SMR 5.0) in HS4 (v4.2.9.0) with plug-in v4.0.11.0.
    I have configured the plug-in to connect over my network, and the logging is showing it is connected.
    The plug-in only creates a root device “Smart meter” and a feature “DMSR version”, that it.
    When I open the Smart meter P1 page of this device I get the following error:
    Error with device config page JSON: Value cannot be null. Parameter name: value
    What am I doing wrong?
    Plug-in start:
    3-07-2022 22:08:34
    Smart Meter P1
    Info
    Slimme Meter: Connected to 192.168.1.75:2000
    3-07-2022 22:08:34
    Smart Meter P1
    Debug
    Slimme Meter: Thread started
    3-07-2022 22:08:34
    Smart Meter P1
    Debug
    Slimme Meter: Thread created
    3-07-2022 22:08:34
    HomeSeer
    Plug-In
    Finished initializing plug-in Smart Meter P1
    3-07-2022 22:08:34
    HomeSeer
    Starting Plug-In
    Smart Meter P1 loaded in 701 milliseconds
    3-07-2022 22:08:34
    HomeSeer
    Starting Plug-In
    Plugin Smart Meter P1 started successfully in 112 milliseconds
    3-07-2022 22:08:34
    Smart Meter P1
    Info
    Initialization of Smart Meter P1 version 4.0.11.0 complete
    3-07-2022 22:08:34
    Smart Meter P1
    Info
    mono version detected: 6.12.0.122 (tarball Mon Feb 22 17:42:49 UTC 2021)
    3-07-2022 22:08:34
    HomeSeer
    Starting Plug-In
    Initializing plugin Smart Meter P1 ...
    3-07-2022 22:08:34
    HomeSeer
    Info
    Plugin SmartMeter with instance Smart Meter P1 has connected. IP:127.0.0.1:53638
    Diagnostics trace:
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: !C06E
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 0-1:24.2.1(220307215502W)(01816.667*m3)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 0-1:96.1.0(4730303339303031373631363336323137)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 0-1:24.1.0(003)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 1-0:22.7.0(00.000*kW)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 1-0:21.7.0(00.398*kW)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 1-0:31.7.0(003*A)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 1-0:32.7.0(239.0*V)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 0-0:96.13.0()
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 1-0:32.36.0(00004)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 1-0:32.32.0(00016)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 1-0:99.97.0(3)(0-0:96.7.19)(180416120452S)(0000003306*s)(191108062450W)(00000 02799*s)(211207134729W)(0000002682*s)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 0-0:96.7.9(00003)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 0-0:96.7.21(00002)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 1-0:2.7.0(00.000*kW)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 1-0:1.7.0(00.398*kW)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 0-0:96.14.0(0002)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 1-0:2.8.2(000000.000*kWh)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 1-0:2.8.1(000000.000*kWh)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 1-0:1.8.2(009351.960*kWh)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 1-0:1.8.1(008434.948*kWh)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 0-0:96.1.1(4530303435303034303439303731323137)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 0-0:1.0.0(220307215733W)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: 1-3:0.2.8(50)
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter:
    3-07-2022 21:57:37
    Smart Meter P1
    Trace
    Slimme Meter: /XMX5LGBBLA4415366814
    3-07-2022 21:57:36
    Smart Meter P1
    Trace
    Slimme Meter: !BFF8
    3-07-2022 21:57:36
    Smart Meter P1
    Trace
    Hi! Sorry you are having issues. Please try the latest beta (4.0.11.6) to see if that helps. It should at least resolve the config page JSON error.
    If there are still no features being created, it often is caused by corrupted messages. Please enable "Log data received" and "Log to file" and check if you can spot any corruption in the logfile (in the Logs directory of your HomeSeer directory).
    stefxx
      This beta solved most of the problems 👍
      The features were created (for the smart meter and the gas meter and the power failure devices) and it solves the config page json error for the smart meter device.
      The gas meter device and the power failure device are still generating a config page json error.
        Thanks. I have created a new release version so we have a stable version again.
        A next version will also resolve the issue with the Gas and Power Failure properties. It will show something like "Nothing to configure here"
        stefxx
          Thank you!
