Release 4.0.13.0, no value updates
    Hi,
    Update to Release 4.0.13.0,
    Now de values are not updated anny more.
    Please fix
    It works for me so unsure what to fix.
    Any errors in the log? What version of HS4? Windows or Linux?
    stefxx
      No errors, HS4 version 4.2.7. WINDOWS 10 Pro
      Just update the plugin and it stops working.
      No other changes.
      How can I go back to the working version?
      Click image for larger version  Name:	last-change.jpg Views:	0 Size:	4.3 KB ID:	1530921Click image for larger version  Name:	log.jpg Views:	0 Size:	27.2 KB ID:	1530922
        Now I think about it, I might be referencing the new PluginSDK available in HS4 4.2.9.0 that is still in beta.
        Any chance you can upgrade to 4.2.9.0? It has been quite stable for me so far.
        https://forums.homeseer.com/forum/hs...0-is-available
        stefxx
          HS4.2.7 is running as a service on my system (for a long time)
            I do not prefer to install an beta.
              OK, you can restore HSPI_SmartMeter.exe from a backup, that should fix the problem for now. I can send it to you as well if you prefer. I assume you were running the latest stable 4.0.11.0?
              stefxx
                This gives strange messages in the log, and still no data
                  Something went wrong with the restore, because that error is not coming from 4.0.11.0.
                  Anyway, you can find it here as well: https://download.dedroog.com/HSPI_SmartMeter 4.0.11.0.zip. Just unzip and place the exe in your HomeSeer directory, overwriting the existing HSPI_SmartMeter.exe.
                  stefxx
                    Yes there must went sommething wrong with copy/past.
                    It's working again (4.0.11.0)
