Hi,
Installed ser2net on a PI.
> /etc/ser2net.yaml
connection: &con0096
accepter: tcp,2000
enable: on
options:
banner: *banner
kickolduser: true
telnet-brk-on-sync: true
connector: serialdev,
/dev/ttyUSB0,
115200n81,localconnection: &con0096
Connected to powermeter Kaifa MA304.
Plugin version 4.0.14.0. Trial version.
Running Linux
Version
HS4 Standard Edition 4.2.12.8 (Linux)
MONO Version
Mono JIT compiler version 6.12.0.122 (tarball Mon Feb 22 17:33:28 UTC 2021)Version
Connection is ok. Debug log reported this:
25/05/2022 22:36:41 Thread started
25/05/2022 22:36:41 Connected to 192.168.1.52:2000
25/05/2022 22:36:41 Thread ReceiveCallback: Index was outside the bounds of the array.
No HS devices are created.
When i telnet to port 2000 from the PI i receive every 5 seconds data from powermeter.
root@linux12:/usr/local/HomeSeer/Logs# telnet p1-interface1 2000
Trying 192.168.1.52...
Connected to p1-interface1.
Escape character is '^]'.
ser2net port tcp,2000 device serialdev, /dev/ttyUSB0, 115200n81,local [] (Debian GNU/Linux)
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:1.0.0(220525224046S)
0-0:96.1.1(4530303033303030303038373731303134)
1-0:1.8.1(028105.444*kWh)
1-0:1.8.2(022316.565*kWh)
1-0:2.8.1(000000.000*kWh)
1-0:2.8.2(000000.000*kWh)
0-0:96.14.0(0001)
1-0:1.7.0(00.629*kW)
1-0:2.7.0(00.000*kW)
0-0:96.7.21(00020)
0-0:96.7.9(00009)
1-0:99.97.0(2)(0-0:96.7.19)(201217052006W)(0000000286*s)(000101000014W)(21474 83647*s)
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00000)
1-0:52.36.0(00000)
1-0:72.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(002*A)
1-0:51.7.0(000*A)
1-0:71.7.0(000*A)
1-0:21.7.0(00.436*kW)
1-0:22.7.0(00.000*kW)
1-0:41.7.0(00.095*kW)
1-0:42.7.0(00.000*kW)
1-0:61.7.0(00.081*kW)
1-0:62.7.0(00.000*kW)
!6744
Before i buy this plugin i have to know what the problem is. Any suggestions?
Regards, Walter
> /etc/ser2net.yaml
accepter: tcp,2000
enable: on
options:
banner: *banner
kickolduser: true
/dev/ttyUSB0,
Running Linux
Version
MONO Version
/KFM5KAIFA-METER
1-3:0.2.8(42)
0-0:96.14.0(0001)
0-0:96.7.21(00020)
0-0:96.7.9(00009)
1-0:32.32.0(00000)
1-0:52.32.0(00000)
1-0:72.32.0(00000)
1-0:32.36.0(00000)
1-0:52.36.0(00000)
1-0:72.36.0(00000)
0-0:96.13.1()
0-0:96.13.0()
1-0:31.7.0(002*A)
1-0:51.7.0(000*A)
1-0:71.7.0(000*A)
!6744
Regards, Walter
