Originally posted by zwolfpack
View Post
Network setup with Ubuntu 22.04 LTS intsalled on RPi4
Originally posted by stefxx View PostWhat is "telnet: 600" in your yaml file? in the conf file, 600 refers to timeout, so I think it should be "timeout: 600", right?
Code:connection: &con0096 accepter: telnet,2000 enable: on options: banner: *banner kickolduser: true telnet-brk-on-sync: true connector: serialdev, /dev/ttyS0, 115200n81,local
stefxx
Not related to this issue.
I try to set-up two (2) meters one for the Primary Allocation Point (PAP) and the other for the Secondary Allocation Point (SAP). As the SAP is currently not installed (will be installed on 31MAY2023) I did split the signal from the PAP. Only one (1) meter is created in HomeSeer. Is this the expected behavior?
Originally posted by stefxx View PostSo you've splitted the signal from a single P1 port, and fed them both into the plugin? Yes, that means it will simply receive the same data twice and won't create an additional meter in HS4. So that is indeed expected.
Originally posted by stefxx View PostI just upgraded my Pi4 with Ubuntu 22.04 LTS and installed ser2net 4.3.4. I used this ser2net.yaml:
Code:connection: &con0096 accepter: tcp,2000 connector: serialdev, /dev/ttyUSB0, 115200n81,local
Code:%YAML 1.1 --- # This is a ser2net configuration file, tailored to be rather # simple. # # Find detailed documentation in ser2net.yaml(5) # A fully featured configuration file is in # /usr/share/doc/ser2net/examples/ser2net.yaml.gz # # If you find your configuration more useful than this very simple # one, please submit it as a bugreport #define: &banner \r\nser2net port \p device \d [\B] (Debian GNU/Linux)\r\n\r\n connection: &con0096 accepter: tcp,2000 connector: serialdev, /dev/ttyUSB0, 115200n81,local
Really, all I did was a clean (remote) install of Ubuntu 22.04 Server (no desktop, ssh enabled) using the Raspberry installer, and installed ser2net using "apt install ser2net". No other configuration has been done, except editing the ser2net.yaml file.
Don't understand why it doesn't work for you. If there was anything else (like a firewall) it would impact the ser2net.conf setup as well.
Anything in the ser2net log that might be helpful?stefxx
Originally posted by stefxx View PostReally, all I did was a clean (remote) install of Ubuntu 22.04 Server (no desktop, ssh enabled) using the Raspberry installer, and installed ser2net using "apt install ser2net". No other configuration has been done, except editing the ser2net.yaml file.
Under /var/log there is no log file for ser2net
My install method was identical, except that I also installed Webmin.
