Network setup with Ubuntu 22.04 LTS intsalled on RPi4
    I installed Ubuntu 22.04 LTS on a RPi4. Installed Ser2net.
    Instead of a ser2met.conf file a ser2net.yaml file was created.
    I did the configuration as follows:
    define: &banner \r\nser2net port \p device \d [\B] (Debian GNU/Linux)\r\n\r\n
    connection: &con0096
    accepter: tcp,2000
    enable: on
    options:
    banner: *banner
    kickolduser: true
    telnet: 600
    connector: serialdev,
    /dev/ttyS0,
    115200n81,local
    In the HomeSeer log there is the following:
    5/24/2023 9:23:06 PM
    Smart Meter P1
    Trace
    SAP:
    Smart Meter P1
    Info
    SAP: Connected to 192.168.1.210:2000
    Smart Meter P1
    Info
    Initialization of Smart Meter P1 version 4.0.16.0 complete
    Smart Meter P1
    Info
    mono version detected: 6.12.0.182 (tarball Tue Jun 14 22:35:00 UTC 2022)
    ​Although the connection is established I will not retreive any data.
    Any idea what to change in the yaml file?
    John
    If you use telnet or putty to connect to that ip/port, do you get any data?
    (disable the plugin first so the port is not in use of course)
    stefxx
      Need to trouvleshoot further as after using telnet all connections are refused.
        stefxx
        YAML seems to be the way to go in the future. But all connections are refused. Will give up for now.
          Seems there is communication however I get the following:
          5/25/2023 10:27:05 AM Thread created
          5/25/2023 10:27:05 AM Thread started
          5/25/2023 10:27:05 AM Connected to 192.168.1.210:2000
          5/25/2023 10:27:05 AM Thread ReceiveCallback: Index was outside the bounds of the array.
            Progress!
            Most likely the data is corrupt. Do you get valid data with telnet?
            stefxx
              Progress!
              No data with telnet.
              Im affraid that it has to do with the YAML file.
                  accepter: tcp,2000
                  enable: on
                  options:
                    banner: *banner
                    kickolduser: true
                    telnet-brk-on-sync: true
                            /dev/ttyS0,
                            9600n81,local
                accepter: tcp,2000
                enable: on
                options:
                banner: *banner
                kickolduser: true
                /dev/ttyS0,
                9600n81,local
                stefxx
                The workaround (for how long it last) is to use the old configuration format.
                In this case I will get "WARNING: Using old config file. format, this will go away soon. Please switch to the yaml-based format"
                Do you have any idea how to convert between the old format and the new (yaml) format?
                  I will try to update my ser2net and see if I can get it working with the yaml configuration file, hopefully later today.
                  stefxx
                    Hopefully it will update the old config file automatically to yaml when updating sernet.
                      Can you show me your ser2net.conf?
                      stefxx
                        2000:telnet:600:/dev/ttyUSB0:115200 8DATABITS NONE 1STOPBIT banner
                          Thanks.
                          In the yaml examples you are using ttyS0, but in the conf it is ttyUSB0. Could that be your problem?
                          stefxx
                            Thanks.
                            When I change the yaml to
                                accepter: tcp,2000
                                enable: on
                                options:
                                  banner: *banner
                                  kickolduser: true
                                          /dev/ttyUSB0,
                                          115200n81,local
                            Also no luck
                              Try changing the "accepter" line to "accepter: telnet,2000"
                              accepter "tcp" corresponds to field 2 = "raw" in the old .conf format.
