Hi... I had some initial success with Solaredge Plugin 4.0.10.0. I was doing this iteratively and ended up moving my inverters to a new IP and somehow in the process of deleting inverters and re-adding them, uninstalling Solaredge Plugin and re-installing, I seem to be left with some part of my previous configuration active and/or other problem. That is when I install a fresh plug-in, it starts up and crashes prior to me being able to setup a new inverter. I am also seeing some stub inverters that show up in the Devices list, every time is crashes and restarts, it creates a new device.
Homeseer Version: 4.1.11.0
Any ideas where to clean up / adjust ?
Application: HSPI_SolarEdge.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.NullReferenceException
at Microsoft.VisualBasic.CompilerServices.Symbols+Container..ct or(System.Object)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGe t(System.Object, System.Type, System.String, System.Object[], System.String[], System.Type[], Boolean[])
at HSPI_SolarEdge.SolarEdge.PollSolarEdgeModbus(GatewayDevice, Byte[])
at HSPI_SolarEdge.SolarEdge.PollSolarEdgeModbusTcp(GatewayDevic e)
at HSPI_SolarEdge.SolarEdge.PollSolarEdge(GatewayDevice)
at HSPI_SolarEdge.SolarEdge.PollGateway(GatewayDevice)
at HSPI_SolarEdge.HSPI+_Closure$__._Lambda$__R2-1(System.Object)
at System.Threading.ThreadHelper.ThreadStart_Context(System.Obj ect)
at System.Threading.ExecutionContext.RunInternal(System.Threadi ng.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.Execu tionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.Execu tionContext, System.Threading.ContextCallback, System.Object)
at System.Threading.ThreadHelper.ThreadStart(System.Object)
