Tank Utility crashing in 4.1.2.0
    Hello, since upgrading to HS4 4.1.2.0, the Tank Utility executable crashes almost immediately after starting. Updating to 4.1.3.0 did not resolve. When executed from the command line, the first two lines displayed are:
    Unhandled Exception: System.NullReferenceException: Object reference not set to an instance of an object.
    at HSPI_TankUtil.CurrentPlugin.UpdateValuesFromServer(Object obj)
    Running HS4 on Windows Server 2016. I can't say for certain whether the crash started at the time of updating HS4, or due to a Windows update.
    Thanks, hope the parent situation is better.
    With a little work, much of the info that this plugin used to provide when it worked can be obtained from data.tankutility.com using their API. Screenshots show basic setup, API account and token are required to retrieve the data. I use an event that fires twice per day to pull the data (I believe the WiFi device only updates once per day).
Name:	Big 6 Profile.jpg
Name:	Timer Event.jpg
      mcsMQTT plugin supports Tank Utility. Data appears as a set of HS Device Features. User just need to enter the login credentials in the setup.
