I had briefly considered this and decided against it because I figured there wouldn't be any HS users with multiple gateways. Of course there is...!
Unfortunately, it would consider some fairly significant re-architecting of the plugin to enable tracking of multiple gateways, and of course HS removed the ability to run multiple instances of a plugin in HS4, so I'd say that this is unlikely to ever be supported. Really sorry about that.
