Hello fellow UltraECM3 users I got a question. I noticed a couple of issues with my GEM and UltraECM3 plug in recently. My 5 temperature probes all began to read 32F. I checked the GEM and it is reporting the same so its not the plugin and I haven't begun to determine what has happened although welcome to any assistance from the group if this happen to you before?
Secondly, while I am logged into the GEM I noticed that there is quite a delay (over 8-10 minutes) before the plugin's device values update vs the realtime GEM values. I recently installed an EV car charger for my son and I planned to use to capture the charging cost of electricity. It reports the load accurately but takes almost 7 minutes to report the charger load to the plugin and between 8-10 minutes to report when the charger load stops.
Could this be as simple as my set up? I haven't touched it in a couple of years. The GEM packets are setup for Realtime Status on, Bin48-NET-Time, Primary packet send interval 8 secs.
Any suggestions?
Any suggestions?
