UltraECM HSPI For HomeSeer [NEW]
This is a sticky topic.
  • #31
    I just connected a 2nd 1240 and don't see any units or devices at all. Everything looks ok in the ECM engine. Plug-in says status connected and SQLite is online
    I tuned on debug and see this: 12/3/2011 2:28:00 PM - UltraECM Debug - Entered ProcessReceived() function with string 'CH1PAa=591&CH2PAa=0&CH1PPa=591&CH2PPa=0&CH1Aa=5&CH2Aa=0.1&P aux1a=442&Paux2a=72&Paux3a=47&Paux4a=0&Paux5a=12&KWhCH1a=611 7.907&KWhCH2a=0.99&KWhAux1a=486.528&KWhAux2a=389.266&KWhAux3 a=463.443&KWhAux4a=326.162&KWhAux5a=135.404&Timea=14:28:00&V olta=122.5&DevSNa=234768'
    Any ideas?
    Regards
    Mark
    ________________________
    Dell Zino HD - HSPRo 2.x
    HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
    2 x Brultech ECM1240 with UltraECM
    USB UIRT
    Cooper Aspire Z-Wave Switches
    WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
    HM ST812-2 Flood Sensor
    HSM100 - Motion Detector with Light and Temperature
    2GIG Thermostat
    BLDSC - Alarm Plug-in
    BLUPS
    UltraLog (SQL2008)
    Jon00 Plugins
    Host XR3 BT and Jon00 BT Proximity
    Global Cache IP2IR
    Foscam FI8918W
    • #32
      Now device A has come back on, but still no device B
      USB UIRT
      2GIG Thermostat
      BLUPS
      UltraLog (SQL2008)
      Jon00 Plugins
      Global Cache IP2IR
      Foscam FI8918W
      • #33
        That is strange. If the Brultech Engine is configured properly, it should be sending a query string output for both Device A and Device B:
        12/4/2011 9:42:59 AM UltraECM Debug Entered ProcessReceived() function with string 'CH1PAa=1678&CH2PAa=0&CH1PPa=1678&CH2PPa=0&CH1Aa=13.1&CH2Aa= 0.1&Paux1a=0&Paux2a=0&Paux3a=6&Paux4a=8&Paux5a=158&KWhCH1a=1 1304871.624&KWhCH2a=7025447.601&KWhAux1a=189.324&KWhAux2a=70 .347&KWhAux3a=20.56&KWhAux4a=148.528&KWhAux5a=518.92&Timea=0 9:42:59&Volta=122.7&DevSNa=945441'
        12/4/2011 9:42:59 AM UltraECM Debug Entered ProcessReceived() function with string 'CH1PAb=99&CH2PAb=230&CH1PPb=0&CH2PPb=0&CH1Ab=0.9&CH2Ab=2.4& Paux1b=281&Paux2b=2&Paux3b=14&Paux4b=933&Paux5b=1&KWhCH1b=16 187556.674&KWhCH2b=610.737&KWhAux1b=768.473&KWhAux2b=281.388 &KWhAux3b=325.675&KWhAux4b=1040.599&KWhAux5b=22.034&Timeb=09 :42:59&Voltb=124.9&DevSNb=333409'
        What version of the Brultech Engine are you using?
        Ultrajones
        • #34
          Originally posted by Ultrajones View Post
          That is strange. The query string should show device B. What version of the Brultech Engine are you using?
          Thanks for reply UltraJones. turned out there was a problem on Brultech side. I didn't set the Cmd Byte for the second unit. I now see both units
          I have a question about the config. Does the plug-in jsut use the Server section of the Home Automation plug-in section? I'd like to use the clients section (at top) to forward data to Check-it
          Regards
          Mark
          USB UIRT
          2GIG Thermostat
          BLUPS
          UltraLog (SQL2008)
          Jon00 Plugins
          Global Cache IP2IR
          Foscam FI8918W
          • #35
            The believe the Brultech Engine allows you to configure both a client and a server for data forwarding.
