Error - Fixed!
  • Error - Fixed!
    When trying to pull up the config page from the interfaces tab, I received the error pasted below. This is a new HS install, running this plug in via trial mode, on a new machine, Windows 7 Home, 64 bit, latest Windows updates. Everything else, including other Ultra plug ins are running just fine. It almost seems like something didn't install correctly!? Uninstalled and re-installed the plug in, no luck.
    System.MissingMemberException: Public member 'WEBUserRolesAuthorized' on type 'MarshalByRefObject' not found. at Microsoft.VisualBasic.CompilerServices.Symbols.Container.Get Members(String& MemberName, Boolean ReportErrors) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGe t(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack) at ASP.hspi_ultraecm_hspi_ultraecm_aspx.Page_Load(Object sender, EventArgs e) in C:\Program Files (x86)\HomeSeer HSPRO\html\hspi_ultraecm\hspi_ultraecm.aspx:line 89
    And to add, the plug in is running. After manually updating the configuration via the ini file, I received the following in the log file:
    8/3/2010 11:51:30 AM UltraECM Error ECM Watchdog Timer indicates no response from the ECM Engine for 60 seconds. Attempting to reconnect ...
    8/3/2010 11:51:30 AM UltraECM Info Database connection closed successfuly.
    8/3/2010 11:51:31 AM UltraECM Info Database initialization complete. Ready to accept HomeSeer events into database.
    8/3/2010 11:51:31 AM UltraECM Info ECM Watchdog Timer reconnect attempt succeeded.
    8/3/2010 11:51:36 AM UltraECM Info Brultech EngineG sending data for device A
    UPDATE: Saw someone received the same error with UltraWeatherBug. So, as and FYI, HS is not running as a service.
    HS: 2.5.0.60
    Environment: Virtual XP as guest in VMWare Server running under Win 7
    Plug-ins: MLHSPlugin|RCS Serial Thermostat|UltraLog|UltraMon|
    Misc: 303 Devices, 313 Events, 68+ Scripts
    HSeer: 3.0.0.54
    Plug-ins: BLGData|BLRF|BLRadar|BLRandom|BLSpeech
    UltraM1G3|UltraECM3|UltraMon3|UPBSpud|Z-Wave
    Misc: 148 Devices, 116 Events, 9+ Scripts (so far, still converting)
    Fixed
    Figured out what the problem was. For some reason, the bin directory was missing under the html/hspi_ultraecm directory. Manually created the directory, copied the dll into the directory and all is fine. Case closed.
    HS: 2.5.0.60
    HSeer: 3.0.0.54
      I didn't think copying the plug-in dll to the plug-in bin directory was required anymore. What version of HomeSeer are you running?
        Windows 7 Home Premium, 64 bit.
        HS: 2.5.0.60
        HSeer: 3.0.0.54
