Originally posted by Ultrajones
View Post
I tried your suggestion above by selecting a different output, rebooting, selecting Packet 5 Binary, Rebooting GEM,and restarting HS but nothing diff happened.
What's diff about this setup is I had to do many resets of the GEM (using PB button on bottom) and when I was hooking it back up the RJ45 connection on Ethernet adapter was ripped off when my network switch fell. So I am using WiFi Connection now until a new ethernet card arrives.
Also if I recall from before I had the GEM set as a Client and your plugin set as a Server. But now the only way I can get the setup to work is when the GEM is in server mode and your plugin set as Client.
In summary, your plugin works with the above settings but the HS log is flooded with the above 2 errors.
Any other thoughts?
