New GEM COM Firmware v2.56
    Ben at Brultech sent me some new COM firmware today. It was V2.56. We were trying it to see if it cured the occasional lockup and disconnects. There must have been some change in the data structure because it littered my HS log with errors. Here is a sample:
    Mar-24 7:34:04 PM Database There were errors generated during the save of the database item. Please consult this log for more details and report any data loss to HomeSeer Technologies. Mar-24 7:34:03 PM Database Error - Save of the devices to the database did not succeed - see the log for more details. Mar-24 7:34:02 PM Database ERROR, device GEM Energy Watts Realtime [LR AC] failed to be updated or added to the database. Mar-24 7:34:02 PM Error SQL Exception updating device record in the database: SQL logic error or missing databaseno such column: NaN, Code=1, Link= Mar-24 7:34:02 PM Database ERROR, device GEM Energy Watts Realtime [BR AC] failed to be updated or added to the database. Mar-24 7:34:02 PM Error SQL Exception updating device record in the database: SQL logic error or missing databaseno such column: NaN, Code=1, Link= Mar-24 7:34:02 PM Database ERROR, device GEM Energy Watts Realtime [Shed Subpanel] failed to be updated or added to the database. Mar-24 7:34:02 PM Error SQL Exception updating device record in the database: SQL logic error or missing databaseno such column: NaN, Code=1, Link= Mar-24 7:34:02 PM Database ERROR, device GEM Energy Watts Realtime [MR S, Exercise Closet, E1, E2, S1] failed to be updated or added to the database. Mar-24 7:34:02 PM Error SQL Exception updating device record in the database: SQL logic error or missing databaseno such column: NaN, Code=1, Link= Mar-24 7:34:02 PM Database ERROR, device GEM Energy Watts Realtime [Computer Closet] failed to be updated or added to the database. Mar-24 7:34:02 PM Error SQL Exception updating device record in the database: SQL logic error or missing databaseno such column: NaN, Code=1, Link= Mar-24 7:34:02 PM Database ERROR, device GEM Energy Watts Realtime [Main] failed to be updated or added to the database. Mar-24 7:34:02 PM Error SQL Exception updating device record in the database: SQL logic error or missing databaseno such column: NaN, Code=1, Link= Mar-24 7:34:01 PM Z-Wave Primary: Z-Wave Wake-Up Notification Received for Node 13 Mar-24 7:34:01 PM Z-Wave Device: 1st Floor Garage Temperature value set to 42.6 (F) Mar-24 7:34:01 PM Z-Wave Device: 1st Floor Garage Luminance value set to 9 (%) Mar-24 7:34:01 PM Event Event Trigger "Test GarageNoMotion" Mar-24 7:34:01 PM Z-Wave Device: 1st Floor Garage Motion Status set to OFF/CLOSED/NO MOTION Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds) Mar-24 7:33:56 PM 1 Error System.OverflowException Mar-24 7:33:56 PM 1 Error System.OverflowException: Arithmetic operation resulted in an overflow. at HSPI_ULTRAECM3.Channel.processWattSeconds(UInt64 wattseconds, Int64 seconds)
    I rolled back to 2.55 and restored a backup database. I will let Ben know. Let me know if at some point I can try the new firmware.
