howdy,
decided to update to ecm2 and am having a problem. had ecm1 working fine using 2 ecm 1240 working fine using a mux adapter via Ethernet. read that had to install a second etherport to get this new plugin to work. have verified that both etherport are talking to the ecm. when setting up ecm2 I get no comm with either port. have followed all instructions found in the forums and I think it maybe a port issue. is there any way to find out what port I need to setup? I am using the same port numbers that the brultech software used.
thanks
steve
thanks
steve
