errors with new setup
  • errors with new setup
    I have installed ultraecm to evaluate with my ecm-1240 and have errors each time i go to the loads page and pops-up every 5-10 seconds. I do not see the graphs when viewing the loads. The error is different for each browser. If I use firefox I get a json error as shown below. If I use firefox I get an unexpected Token and IE I get invalid character. If I open on the homeseer server it self using IE I can see the loads but it displays an error unable to get property as well.
    I am seeing data from the ecm based on the picture of the dashboards attached.
    Can you provide the output of the following two URLS?
    http://yourhomeseerip/hspi_ultraecm3...ta&device_id=1
    Ultrajones
      Here are the outputs.
      [ {"Channel":"1","Watts":"6197","WattMax":"19266"},
      {"Channel":"2","Watts":"6536","WattMax":"10081"},
      {"Channel":"3","Watts":"737","WattMax":"2963"},
      {"Channel":"4","Watts":"37","WattMax":"8869"},
      {"Channel":"5","Watts":"40","WattMax":"7120"},
      {"Channel":"6","Watts":"40","WattMax":"11394"},
      {"Channel":"7","Watts":"37","WattMax":"92"}, ]
      [ {"Channel":"1","Name":"House"}, {"Channel":"2","Name":"AC Condensor"},
      {"Channel":"3","Name":"AC Air Handler"}, {"Channel":"4","Name":"Dryer"},
      {"Channel":"5","Name":"Stove"}, {"Channel":"6","Name":"Water Heater"},
      {"Channel":"7","Name":"Channel 7"} ]
        Are you using HS2 or HS3?
          I am using homeseer 3.
            Any comments on this error, I am running the 30 day trial and have about 10 days left before I have to remove it. I do not want to purchase if it is not working.
              Yes, it is a bug associated with the ECM-1240. I am surprised no one else every reported this. I'll work on the fix tonight.
              Ultrajones
                Please download and installed UltraECM3 HSPI version 3.0.5378.31939 to see if it fixes the issue you reported.
                Ultrajones
