Ok so I'm picking up 2 of the BRU-Tech ECM-1240 kits and a RSR-232 to Ethernet kit. When the MUX is back in stock I'll grab one of them.
Is there anything I need to be aware of prior to installing these guys with my HS3 system? From the board it seems like they work well with the UltraECM plugin and HS3.
Looking to visually see energy usage by home and circuit (and a couple appliances like the dryer and fridges and freezers). Would like to work the displays into my custom hstouch interface (likely using HTML, again).
I know this isn't the spot for it, but can anyone suggest a clean / safe way to monitor water and gas usage too?
