Possible bug - ECM3 disable channel
  • Possible bug - ECM3 disable channel
    I'm seeing an issue with ECM3 where if I try to uncheck the enable checkbox in the Channels tab for either channel 21 or 22, ECM3 will essentially crash. After that I can no longer enter the ECM3 setup. The only way I have been able to recover is to restore HomeSeer to a previous backup. Even a reinstall of ECM3 did not fix it. Has anyone else seen this? Is there a fix or workaround?
    Wow, this doesn't make any sense. I have both channel 21 and 22 enabled and working fine. What are you seeing in the logs? What are the names of your channel 21 and 22?
    Ultrajones
