Setup - cannot connect to ECM1240
  • Setup - cannot connect to ECM1240
    I am trying to configure UltraECM2 on a HS2, and UltraECM3 on a HS3, and am running into the exact same error.
    "Ethernet connection could not be made to 192.168.111.120 (192.168.111.120:8082) - No connection could be made because the target machine actively refused it 192.168.111.120:8082"
    I have a single ECM1240 connected to EtherPort RS232 to ethernet interface.
    The Etherport address is .122
    Homeserver server is .120
    I am assuming I am using the correct ip address... I have the ECM set up in client mode.
    I also tried configuring UltraECM to use ..122:5000, and that didn't work either.
    I am currently using the HSTens products, and those products can access the ECM. I can also access the ECM with the Brultech IA setup program.
    I have also disabled the firewall and antivirus products...
    Any other thoughts?
    Figured it out... for client mode the address should literally be 0.0.0.0. So the connect string should be 0.0.0.0ort where port is the port #. Do not try to use a real ip-address. RTFM on my part...
