Two questions
  • Two questions
    Recently added a second ECM-1240 and started using UltraECM to handle second one as Brultech was out of stock on mux cable.
    In installation docs (which I didn't read until later) you talk about using Brultech's engine s/w to talk to the 1240's. I had already just set it up with 2 ECM devices on 2 com ports and have everything working fine. Is there an advantage to using the Brultech engine s/w or am I ok?
    Second question: There seems to be some buffering/averaging/?? going on as my device wattage numbers seem to take 3 - 5 seconds or more before they reflect a device having been turned on or off.
    Otherwise, great plug-in and will be paying for it shortly.
    Dick
    HS PRO 2.5.0.81, WinXP, IE8, Shuttle XS35V3, 2.13GHz, 4GB, 40GB SSD drive, AC-RF2, ADIOcelot, Message Server, TI103, SNEVL CID, pjcOutlook, MCSTemperature, Powertrigger, BLBackup, BLFloorplan, BLIcon, BLOccupied, BLRadar, BLRfid, BLLogMonitor, ACPUPSD, UltraECM, WeatherXML & Stipus' script connector. 500+ devices, 260+ events, 1-wire weather station + temp/humidity sensors & Oregon Scientific temp & humidity sensors & 2 Brultech ECM-1240s
    BUMP
    Dick
      You're fine. The UltraECM2/UltraECM3 plug-in does not support the Brultech MUX device. I don't recommend the use of the Brultech software.
      Yes, averaging occurs to reduce the load on your HomeSeer system.
      Ultrajones
        Thanks for the info. Now I'm off to pay for the plug-in.
        Dick
